560 steering shaft help
Clefus
12-09-2007 19:27:11
Fixing small thing on my 560 during the winter and the problem is with the steering shaft....
I removed the steering wheel...below that is a washer and there are 2 grooves on the shaft....
The shaft has considerable wobble and it appears there was maybe a sleeve or bushing worn/missing.....
What goes on the shaft??
I can fab something if I know roughly what is supposed to be there...
ejr-IA
12-10-2007 13:04:38
 Re: 560 steering shaft help in reply to Clefus, 12-09-2007 19:27:11
The bushing is worn out IH part no. 378699R1 snap ring No.359909R1 and washer 358002R1 available at Case IH dealer.
Nat 2
12-10-2007 01:26:31
 Re: 560 steering shaft help in reply to GordoSD, 12-09-2007 19:27:11
Whoops, clicked send before I finished...
The parts books have assembly drawings of everything, so you should be able to get a rough picture of what belongs there. Heck, you might even be able to order the part.
Nat 2
12-10-2007 01:25:31
 Re: 560 steering shaft help in reply to GeneMO, 12-09-2007 19:27:11
They've got online parts books at caseih.com caseih DOT com.
Clefus
12-10-2007 03:28:48
 Re: 560 steering shaft help in reply to Nat 2, 12-10-2007 01:25:31
thanks ---i'll check it out
