Clearance?
FarmallFarris
12-10-2007 20:28:48
I am a tool and die maker. Precision measurements put food on my kids table. Lately I have personally made a lot parts for my 1952 Super M on a Mazak CNC mill and other various equipment. While trying to make a new bushing for my worn steering shaft support, I became uneasy about what "Clearance" actually means. I consulted with my service manual on engine main bearing clearance with no avail. If I were to say that the clearance spec. is .002, does that mean .002 per side with a total of .004, or does that mean .002 with a total of .001 per side?
FarmallFarris
12-11-2007 14:08:16
 Re: Clearance? in reply to FarmallFarris, 12-10-2007 20:28:48
Thanks guys for the info. Ill be finish reaming that bushing this weekend!
El Toro
12-11-2007 05:43:56
That means .001" clearance on each side of the shaft if it calls for .002" clearance. If you need to bore a .750" hole for a 3/4 " shaft and it requires .002" clearance the hole needs to be
bored at .752". Hal
Andy Martin
12-11-2007 04:28:24
When you use plastigage to check journal bearing clearance it definitely is total clearance.
But the guy putting 0.030 bearings on a 0.040 crank main will probably shim 0.010. Presumably he will do this on one side only and raise the crank by 0.005. I noticed lot's of folks reminding him to keep the oil hole open but if he only shims the cap he should be OK. 0.005 shouldn't affect his gear clearances appreciably.
Wardner
12-10-2007 20:58:00
It means "what feeler gauge will slide in the annular space". Don't multiply that measurement by two.
It's kinda like using a boring bar on a Bridgeport. If you dial in 15 thousands on the next cut, the hole will be 0.015" bigger. Not 0.030" bigger.
RedNeckSuperC
12-10-2007 20:52:26
I agree with Dave
As a Millwright, we use total clearance when we measure a bearing.
I hope this helps.
Dave S.
12-10-2007 20:49:53
It means .002 total .001 per side
