Will Wide Front from Farmall 460 Fit Farmall 450?
migraine
12-11-2007 08:20:42
Have a parts 460 diesel with nice I.H. wide front and a 450 with Swartz wide front that sticks out to far forward to suit me. Will these two interchange with out much trouble or should I just put a trike front on it? Thanks
NBAllen
12-11-2007 12:46:31
 Re: Will Wide Front from Farmall 460 Fit Farmall 450? in reply to migraine, 12-11-2007 08:20:42
Hmmm....
I've got a narrow front on a '49 H - If you're looking for a trade...
Nathaniel
Caldwell, ID
D Slater
12-11-2007 10:42:49
ball socket support that bolts to frame will need modified unless you use spacers under the front casting. Original type 450 cast wheels won't be a dirrect bolt on if that makes any differance to you.
MN Scott
12-11-2007 09:36:01
The 460 front will bolt up to the 450 with no modifications.
