Farmall H frontend fit 300 ??
Sam F.
12-11-2007 11:06:09
Will a wide front off an H fit onto a 300. 300 Has single wheel and I know in the past I have swapped a single for the dual narrow with just 4 bolts off and on. Is it this simple for a wide front ??? Thanks
dej(jed)
12-11-2007 11:09:49
 Re: Farmall H frontend fit 300 ?? in reply to Sam F., 12-11-2007 11:06:09
There are a few more bolts , but it is a direct swap.
Steven f/AZ
12-11-2007 11:09:14
Yes, should fit with minimal fuss. You may have to drill a couple holes in the frame rails for the rear supports.
