ih 340 utility gas removing piston sleeves
jimmY Minnesota
12-12-2007 18:09:12
whats the best way to remove piston sleeves out of engine block?? thanks
Janicholson
12-12-2007 18:17:56
 Re: ih 340 utility gas removing piston sleeves in reply to jimmY Minnesota, 12-12-2007 18:09:12
A 340 has an engine design with wet sleeves. The method is to have the crank set so two are up and two are down. Remove the rod caps, and take the piston and cylinder out at the same time by driving them upward with a 2"X2" stick of hard wood and a mallet from below. Be careful not to nick the crank with the loose rod big end. Once they are an inch out, they are out. Clean the grooves for the O rings very well, and use new O rings lubed with silicone grease, or straight dish washing detergent. Make sure the rim relief in the deck of the block is also very clean. A bit of LPS corrosion inhibitor sprayed in that recess is good. JimN
Scott Rukke
12-12-2007 18:38:54
 Re: ih 340 utility gas removing piston sleeves in reply to Janicholson, 12-12-2007 18:17:56
Man I sure haven't had any luck in driving the sleeves out from the bottom. They never seem to budge for me. I always end up having to pull them. Some are a real bear to get out.
