carburetor on IH 400
BradV
12-12-2007 19:55:20
I"m having trouble getting my 400 started. It hasnt run in a month. It turns over good, and sputters a little bit like it wants to start, but I cant get it to run. I"ve taken the carb apart and cleared the fuel line. Does it sound like a carb adjustment problem? I"ve been monkeying a bit with the adjusting screws, but i just cant get it to run. Any suggestions?
Andy Motteberg
12-12-2007 20:50:00
 Re: carburetor on IH 400 in reply to BradV, 12-12-2007 19:55:20
Check to see if you have good blue spark from the mag/distributor. Be sure that the plugs and wires are in good condition. Make sure the points are clean and gapped. Remove the carburetor drain plug and see if you have a good flow of clean gasoline.
