M hand clutch
David Robinson
12-13-2007 08:59:48
Can anyone tell me if you can creep forward by using the hand clutch on a Farmall M, or, is it a case that your fully engaged or not???
Jaden
12-14-2007 18:54:20
 Re: M hand clutch in reply to David Robinson, 12-13-2007 08:59:48
Gentlemen;
I have never heard of a M hand clutch. Is that an aftermarket item?
Andy Martin
12-13-2007 10:03:05
Yes, you can creep it forward. It is an over center clutch so if you're trying to use it to creep back to an implement and it snaps in you are in trouble because it will take you a precious split second to snap it back out.
It has clutch discs and is not different than slipping a JD hand clutch BUT you will wear it out quicker, just like with a foot clutch.
Nebraska Cowman
12-13-2007 09:15:33
The instructions say to engage the clutch quickly and NOT to slip it.
