Charging a 6 volt battery
JHT113
12-13-2007 09:21:02
I have a old cub , trying to charge the 6 volt battery. Is there anything special that needs to happen other then havinga 6 vold charger?
Thanks
karl f
12-13-2007 13:54:46
 Re: Charging a 6 volt battery in reply to JHT113, 12-13-2007 09:21:02
the Dim position isn't really necessary other than originality. (maybe legality on the road) stock lighting is pretty dim, even on 12v machines of the 70s when on bright/full power with clean connections. the dim and bright difference should have been adding bulbs in my opinion. not to mention relays... ;)
karl f
karl f
12-13-2007 15:44:35
 Re: Charging a 6 volt battery in reply to karl f, 12-13-2007 13:54:46
wrong topic
Mike Farmer
12-13-2007 12:21:34
JohnT that answer covers everything and lt's the most sensible answer that could possibly be given especially the bit about explosive gases, lots of people don't understand that particular danger. MTF
John T
12-13-2007 13:55:34
 Re: Charging a 6 volt battery in reply to Mike Farmer, 12-13-2007 12:21:34
Thanks, I understand it having seen a battery explodeeeee e and as you well know right after or during charging is the most hazardous time as the hydrogen gas is rising at the top ESPECIALLY if a high current quick charge OUCHHHHH
JT
John T
12-13-2007 09:31:58
Nope, using a 6 volt charger just get the polarity correct, + to + and - to - from charger to battery. I dont like to use the high rapid charge settings unless necessary i.e a good long slowwwww wwww low amp rate charge versus high amps for a short time
Have the vent caps removed and good ventilation, make sure electrolyte is at least above the plates, dont let her overcharge n boil over, make the last connection somewhere OTHER THEN the top of battery where the explosive gas may be present i.e. if the battery is grounded to the tractor frame (well DUH unless you removed the ground cable) make the battery charger connection somewhere away from the battery top ESPECIALLY when removing it cuz thats when the gasses are gonna be hanging around the most.
John T
JHT113
12-13-2007 10:33:11
 Re: Charging a 6 volt battery in reply to John T, 12-13-2007 09:31:58
Thanks - JHT113
