460 wide front axle
Farm'em all
12-14-2007 08:25:28
Can anyone tell me if an 06/26/56/66 series wide front axle will fit a 460? Thanks.
Steven f/AZ
12-14-2007 11:19:39
 Re: 460 wide front axle in reply to Farm'em all, 12-14-2007 08:25:28
Will it bolt up with no modifications? No.
Can it be made to fit with a little creativity and fabrication? Yes.
The 4-bolts that hold the main casting of the front end to the tractor have the same spacing from the H thru 1256 for sure (I've measured)... however, the steering arm will need to modified, along with the rear mounts/stay rod support for the front end.
It can be done, but the front of your tractor might be kinda high...
Jim J
12-14-2007 16:03:10
 Re: 460 wide front axle in reply to Steven f/AZ, 12-14-2007 11:19:39
The steering arm and back bracket are the same and won't need modified
