Ih 340 utility tractor clutch release bearing
jimmY Minnesota
12-14-2007 10:53:45
how do i remove relese bearing from clutch housing. any information would be great, thanks
Fromjb2
12-14-2007 19:23:13
 Re: Ih 340 utility tractor clutch release bearing in reply to jimmY Minnesota, 12-14-2007 10:53:45
Jim, never worked on a 340 and never had to change the clutch in the 300U that we had in the late 50s.
With most tractors if you remove the clutch actuator rod on the outside of the housing that will allow the clutch fork to move forward and release the cluch release bearing carrier.
JimB
RustyFarmall
12-14-2007 11:01:22
Do you have the split? That release bearing cannot be removed without first splitting the tractor.
jimmY Minnesota
12-14-2007 15:27:46
 Re: Ih 340 utility tractor clutch release bearing in reply to RustyFarmall, 12-14-2007 11:01:22
yes tractor is split, the shaft rod that goes through the clutch housing and connects to clutch bearing fork assembly inside the housing , question is how do i remove clutch rod through housing, in order to drop out bearing , the clutch rod has no retainer clips or pins to remove.
thanks jim
