F-30NT
Ole Head
12-14-2007 15:23:03
Hey guys I"ve been out of the tractor thing about a year now due to work. I"m jumping in to a F-30 NT project and need to find some parts or a good parts tractor. Im in Tx so a parts machine that is close would be good. Need a carb, manifold, air pipe, throttle and spark controls. Could also use some good closeup pictures of some area"s. These things are slightly different from the 20.
F-Dean
12-15-2007 10:39:02
 Re: F-30NT in reply to Ole Head, 12-14-2007 15:23:03
No and No. The exterior of the carb is the same but the F-30 and the F-20 have different jets. Also, the larger engine makes the length of the pipe different.
sgtbull
12-15-2007 08:39:39
I believe it takes a Zenith K-5, like the F-20. Air pipe should be the same. As far as I know, most of the differences are in the rear end.
F-Dean
12-15-2007 06:27:16
Only slightly different. Rice Equipment (814) 226-9200 should have most of the parts you need. Many of the parts are the same as a F-20, 10-20 or W-30.
ole head
12-15-2007 08:35:33
 Re: F-30NT in reply to F-Dean, 12-15-2007 06:27:16
is the carb and air pipe the same?
