Re: ??'s 240 fast hitch hydraulics
glennster
12-15-2007 15:20:52
from what i read in the owners manual, the hydraulics can be adjusted for one way or two way. also under the seat, there is a cast iron ?? box about 1/2 the size of a cigar box and half as thick. the lines come from the valve under the steering column in steel lines and then connect to this box. coming out from under the seat heading back to the cylinder they are rubber coated hydraulic lines. maybe flip the two lines at this block? there are no linkages at this block, nor is there any other knobs, levers, or adjustment screws that i can see, just looks line 2 lines in, two lines out.
georgeky
12-15-2007 16:22:11
 Re: ??'s 240 fast hitch hydraulics in reply to glennster, 12-15-2007 15:20:52
Glenn, I am thinking there was something about the control handle. I think mine would whine at certain positions until wiggled a little. Been so long I just can't remember what the deal on it was. Sold the little unit in 94 or 95 in favor of another SC. I use the SC to cultivate tobacco, and fit my needs a lot better. I have often wished I had kept it, but can't have everything I guess. I had trouble on my 350 with a safety check valve. It would always lift but, It would only let down sometimes and then quit all together. Don't know exactly what was wrong with it as I had an extra, and just swapped them out.
