F-20 front motor mount bracket
Scott Rukke
12-15-2007 16:25:48
How does the front motor mount cross member separate from the front cover?
Nebraska Cowman
12-16-2007 03:31:59
 Re: F-20 front motor mount bracket in reply to Scott Rukke, 12-15-2007 16:25:48
I have seen them stuck on awful tight. You might have to use heat. I even have cut them off. If you break it another one will not be hard to come by.
James Williams
12-15-2007 17:28:18
Scott,The front of the motor has a peice bolted to it with 4 bolts which has a round flange made to it.The front support has a round flange that slips over the peice that is bolted to the motor.With the front support loose and motor lifted up the front support should slide of.might have to tap it with a hammer
jimmy
