H vs super H crankshaft
skk-big red fan
12-15-2007 20:45:13
Do you have to line bore a std H block to use a super H crank, or only use the main and rod bearings for a super H with the super H crank?
El Toro
12-16-2007 06:48:48
 Re: H vs super H crankshaft in reply to skk-big red fan, 12-15-2007 20:45:13
There's a difference between the H's before S/N
391358 as the rod journals and mains were smaller in diameter. From S/N 391358 and up they were same diameter as the Super H's. The mains are about .060" thicker and the rods are about .050" thicker. I don't know if the same rods are the same on both tractors. Hal
Andrew Z
12-16-2007 06:59:39
 Re: H vs super H crankshaft in reply to El Toro, 12-16-2007 06:48:48
The rods from the H can be used in the Super H or vice versa. The reason is that the Super H uses thinner bearings, than the H.
Andrew
georgeky
12-16-2007 05:34:23
Best I remember the main journals are the only thing different between the two. So just use the SH main berings as the others are the same.
