attn: tractor vet
redpowerman
12-16-2007 11:32:02
Hello; I have a Farmall 656 with leaky TA seals the Ta seems to work fine.I was wondering if youv'e ever just replaced the seals and not the TA? Also the brake shaft seals leak,I've put speedy sleeves on the brake shaft and new seals,but it still leaks.Can you still buy this shaft from Case-IH. Thank-You!
Kevin Meier
12-16-2007 15:43:25
 Re: attn: tractor vet in reply to redpowerman, 12-16-2007 11:32:02
I know you were asking for the tractor vet"s response but if it were mine I would at least pull the t/a out and inspect the upper seal area, the sun gears, topshaft and ramp and ramp area on the carrier.
