706 Model Number
Mel Shaw
12-16-2007 16:33:37
OK, I'm looking for the model number for an 706 and I'm not sure where to look. It's the MODEL # I need. Thanks
GeneMO
12-16-2007 18:20:15
 Re: 706 Model Number in reply to Mel Shaw, 12-16-2007 16:33:37
At some point the 706 diesels switched to the "German diesel" The serial number should give that away if you run it through the serial number registry on this site. There are many on here who are much more knowledgeable than I am. Maybe they will chime in here soon.
Gene
GeneMO
12-16-2007 17:33:45
There is a serial # plate on the left hand side of the tractor (as you are setting in the drivers seat). It is on the clutch housing.
Hope that helps.
Gene
Mel Shaw
12-16-2007 17:56:19
 Re: 706 Engine number needed in reply to GeneMO, 12-16-2007 17:33:45
Correction. I got the model number, but need engine number. I need the engine number to order main bearings.
the tractor vet
12-17-2007 07:12:55
 Re: 706 Engine number needed in reply to Mel Shaw, 12-16-2007 17:56:19
Well we need to know if it is a gasser or a diesel to tell ya where to look for the engine # . And if you are going to be ordering bearings then one should pull the crank and have it checked before this is done as it my need to be turned or if it has been done a couple times before then ya may need to find a better crank. Never order parts BEFORE YA KNOW FOR SURE JUST WHAT YA NEED.
Armand Tatro
12-16-2007 16:47:23
You have a model#706. Farmall is a row crop tractor. International is a standard/wheatland tractor. Armand
