carb openine on an H
Pat-CT
12-16-2007 18:33:20
the carb on an H wouldnt be 2.5 inches would it?
Pat-CT
12-16-2007 19:26:48
 Re: carb openine on an H in reply to Pat-CT, 12-16-2007 18:33:20
the opening where the coupling from the air filter house meets the carb or the opening of the carb where air ges sucked in
Mike CA
12-16-2007 19:07:19
Sorry Pat, your question wasn't written all that well. Are you asking about the diameter of the opening on the carb of an H? If so, which one? Air intake or mixture outlet? I've got mine off and can measure for you.
kfox
12-17-2007 02:12:12
 Re: carb openine on an H in reply to Mike CA, 12-16-2007 19:07:19
Nope, more like 1 1/2"
ken
RustyFarmall
12-17-2007 08:34:06
 Re: carb openine on an H in reply to kfox, 12-17-2007 02:12:12
Actually, the inside diameter of the hose that connects the carb to the air cleaner pipe is 1 3/4"
