thanks janicholson...240 hyd's solved
glennster
12-17-2007 16:55:47
switched the hydraulic hoses on the 240 fast hitch, solved the problem!! hitch now raises smoothly and goes down without making a bold statement!!! hitch doesnt stall either. and the controls now work in the correct direction. who ever had the tractor before must have either replaced the hoses or cylinder and put em on wrong!!
GA Dave
12-18-2007 20:20:37
 Re: thanks janicholson...240 hyd's solved in reply to Clefus, 12-17-2007 16:55:47
Looks like there's as many ways to plumb hydraulics as there is to wire a 12 volt conversion!!!!! !!!! David.
Janicholson
12-18-2007 05:53:54
 Re: thanks janicholson...240 hyd's solved in reply to glennster, 12-17-2007 16:55:47
Information giving is best when it is what is needed. May piece beyond understanding find your family and Iron friends. Jim
GA Dave
12-17-2007 19:17:32
 Re: thanks janicholson...240 hyd's solved in reply to russ hamm, 12-17-2007 16:55:47
Good to see some things work out. Is your hydraulic block under the seat like this one? Any idea what the other two plugs are for? David.third party image
glennster
12-18-2007 05:54:25
 Re: thanks janicholson...240 hyd's solved in reply to GA Dave, 12-17-2007 19:17:32
mine only has three outlets on the back, here is the set up. the tractor was missing the linkage from the valve to the control rod, it was also missing the control handle. i fabricated up a rod from some 3/8 cold rolled stock and a handle from some 3/16 flat stock. seems to work ok
third party image
third party image
third party image
georgeky
12-18-2007 02:25:48
David, there are safety and check valves behind those plugs. Remove the plugs to service the valves.
