Couple of Questions
r4etired
12-17-2007 19:18:30
Were the steel belt pulleys an option the H's if so what was the first year. Second question. What year did the lugs on the front rims change from a 2 rivet to a 4 rivet.We are starting to reassemble our club's raffle tractor (1946 H).Central Iowa was IH Heartland so this tractor has to be right. To date we have replaced every seal and gasket.rebuilt the govenor,distributor,carb, water pump,replaced all bearings that were not tight and smooth.New brakes and clutch and installed a Major OH kit in the engine.Totally rebuilt the steering. With the help of a couple retired IH mechanics the project is going well.
Andrew Z
12-17-2007 19:44:11
 Re: Couple of Questions in reply to r4etired, 12-17-2007 19:18:30
I belive the steel came into effect around 52, 53 area the company that made them no longer produced them (rockford) and the same for the 4 rivit rim. Was told the 4 rivit rim was a heavy duty rim.
Andrew
