IH 110 balanced mower pto drive sprocket
twopills
12-17-2007 21:10:04
We are trying to find a supplier for the pto drive sprocket (40 tooth) for a belly mounted 110 balanced sickle bar mower. Case/IH dealership unable to obtain. The mower will be mounted on a SMTA.
georgeky
12-18-2007 02:28:51
 Re: IH 110 balanced mower pto drive sprocket in reply to twopills, 12-17-2007 21:10:04
Like Steven said, those can be made from components from TSC stores. They have the sprockets and hubs to fit the shaft. All you have to do is pay for them and weld the sprocket to the hub.
Steven f/AZ
12-18-2007 01:49:11
A good supplier should be able to set you up with a 540 PTO splined hub and a 40 tooth weld-on sprocket.
I had my sprocket repaired when I fixed up my 1110 mower... but it would have been cheaper to buy a hub and weld on.
third party image
