size round bale 574 can lift
Yellott Canby
12-19-2007 03:52:28
Hello, I was just curious if anyone uses a 574 to move round bales and how large a one it will lift with the 3pt hitch. I have a 656 narrow that struggles to pick up a 1500 pound bale once the oil is warm. Was wondering if the 574 had stronger hydraulics.
Thanks YC
Nat 2
12-19-2007 10:45:46
 Re: size round bale 574 can lift in reply to Allan In NE, 12-19-2007 03:52:28
Yup, fixing the 656 will be a lot cheaper than buying another tractor.
Filter and pump should run a few hundred $$$ but well worth it.
Yellott Canby
12-19-2007 19:13:43
 Re: size round bale 574 can lift in reply to Nat 2, 12-19-2007 10:45:46
I already have the 574 such as it is. I will probably chage out the pump on the 656, perhaps this winter. Thanks
South Texas
12-19-2007 10:08:15
 Re: size round bale 574 can lift in reply to Yellott Canby, 12-19-2007 03:52:28
I agree with Hugh, my 656 will lift the front wheels off the ground when I lift something heavy enough, and I have weights on the front of mine.
georgeky
12-19-2007 06:56:46
Something is wrong with your 656. It will snatch any bale up when in good shape. Sounds like it needs a pump. The 574 will also lift any bale, but will need weights on the front end. The 74/84 series tractors have a very good lift. I think the 574 and 584 are rated about 4000 pounds on the lift I would get the 656 checked out. A new pump for the lift is around 400 bucks.
Yellott Canby
12-19-2007 08:42:24
 Re: size round bale 574 can lift in reply to georgeky, 12-19-2007 06:56:46
I suspect what you say about the 656 is true. The pump seems slow and weak. Glad to here they are both rated so high, as I would like to get a baler that makes 5x6 bales and will be need to be able to move them.
Thanks for the info. YC
georgeky
12-19-2007 23:20:14
 Re: size round bale 574 can lift in reply to Yellott Canby, 12-19-2007 08:42:24
I put a new piggy back pump in my 666 3 years ago. It was about 350 bucks for the pump. Not hard to put in either.
