H head stud locations
neblinc
12-19-2007 10:01:18
I tried to search for this here but could not find it.
Online parts book shows 11 studs 5 15/16 but retired & 5 studs 6 1/8
How do you know where the longer studs go? And do they all get replaced with the longer ones now?
My 43H that I pulled the engine out looks like some of the head nuts are barely covering the threads on some of the studs, wondering if someone got em mixed up or does it matter?
Is there a diagram showing where the longer ones go anywhere?
Randy
neblinc
12-20-2007 11:15:35
 Re: H head stud locations in reply to neblinc, 12-19-2007 10:01:18
Thanks everyone!! BTW great reading on the ARP website Glenn.
Link
Randy
Owen Aaland
12-19-2007 17:39:08
Two long studs go where the throttle pivot bracket is installed on top of the head. The others go where the heavy washers are used. If you inspect the head closely you will find that some of the head stud holes are actually heavy wall tubing pressed into the casting. The washers go over these tubes and extend out far enough the contact the casting so the nut is nut holding just the tube.
glennster
12-19-2007 14:47:18
here is where they are at on the super m, i think the h is prolly pretty close
third party image
Theman
12-20-2007 10:55:25
 Re: H head stud locations in reply to glennster, 12-19-2007 14:47:18
Great pic. That would have been helpful on my first H rebuild. The 5th long stud on the H goes right in the center of the head between the no. 2&3 cylinders.
Mike Farmer
12-19-2007 13:35:51
Hi I've got the manual in front of me and it doesn't specify, except the two long ones for the throttle linkage. The only thing I would suggest is that if they are still in, then leave them cos they sometimes break easy, and it can be a long and expensive job to put right. MTF
RustyFarmall
12-19-2007 11:01:00
Two of those longer studs go where the throttle bracket is installed. The other three go somewhere under the valve cover, but I can't think exactly where.
glennster
12-19-2007 10:10:35
randy, i got my head studs for my super m from the machine shop. he ordered them from arp.....automotive racing products. the whole set with nuts and washers was about 175.00. i-h wanted 280 for the set. they will make them to order.
