Super A Charging, needs flash every time I use it
scott#2
12-19-2007 19:05:19
I admit that it only get used about every other month, so I guess thats the problem. The 6 volt generator puts out voltage and I replaced the volt regulator and it charged perfect after that. Seems whenever it sits a month or so, it needs flashing again. Standard operating procedure, huh?
scott#2
John T
12-19-2007 21:08:26
 Re: Super A Charging, needs flash every time I use it in reply to scott#2, 12-19-2007 19:05:19
Scott, I just dont really see the genny as loosing enough residual field pole magnetism over a short time as the problem and I say its NOT (or shouldnt be) standard procedure or the problem.
That leaves us with possibly a VR or a ground or connection problem. The next time you start her n she dont charge (and before you re polarize) try this:
TO DETERMINE IF ITS A GEN OR VR OR CUTOUT RELAY PROBLEM
5. a) VOLTAGE REGULATOR SYSTEM: With the tractor running, temporarily ground the Gens Field post to case. If she charges then but NOT otherwise, the VR may be bad, or a wires missing from VR's Field post to the Field terminal on the VR, or the VR isn’t well grounded.
b) IF IT’S A CUTOUT RELAY SYSTEM and she charges only if you dead ground the Field but NOT otherwise, its either a bad switch or the switch isn’t well grounded or else the wires bad or open from the Gens Field post up to the switch. INSURE THAT GOOD SWITCH GROUND AND WIRING
6. If she still don’t charge, leave the Field grounded and jump a wire across from the VR or Cutout Relays BAT terminal over to its GEN terminal (jump by passes the cutout relay) and see if she charges. If then but not otherwise, a VR's cutout relay isn’t working correct (maybe points burned/carboned) or a Cutout Relays NOT working or not wired correct.
7. With the 2 steps above, you have basically by passed the VR or Cutout relays functions, so if she still don’t charge, you're left with a bad battery or wiring or the Gen itself.
The next thing is if that temporary field ground gets her to charging and then she still works okay for "a while" without that ground, it still sounds like the VR needs attention like Jim was talkin about. It may need some minor tweaking or perhaps even a good clean/buff/polish of the relay contact points is in order.
Id insure BOTH the genny n VR have good grounds,,,,, ,try the tests I outlined above,,,,, ,,finally, Id try to clean the VR relay contacts and if youre brave enough try the minor adjustments Jim was talkin about.
One last thing Id do is try to clean up the gennys commutator free of carbon or oil and clean n exercise n light lube the brush hold down spring assemblies n make sure the brushes arent worn down too low and that the springys are keeping them pushed down tight against the commutator
let us all know
John T
Janicholson
12-19-2007 19:44:36
Not really, I have seen generators go several years W/O loosing polarization. The pull in voltage of the cutout relay in the new VR is probably set too high.
This adjustment is one that requires a bit of understanding of the content of that can. The cutout has the biggest contacts, with heavy solid wire going to them. There is a spring that pulls these apart when the generator is stopped. This prevents the battery from draining into it when its output is less than bat volts. Low idle, or shut off. A very timid (small) incremental (tiny) loosening of the tension. will get it right. If the system reliably opens when taken to an idle, or shut off, it is then fixed. The needle on the amp gauge will slowly go towards discharge when Idled down all the way, (it may get to 3 amps or so discharge) then it will snap a little and go to just a tiny discharge. The same happens when it is shut off, but the needle goes back to 0 . If the needle goes to 10 or more discharge and stays there, it has been loosened too much. Disconnect the Big wire on the generator to prevent it from getting hot and letting smoke out.
A good book (like Motors automotive dictionary) is a great help. Google Voltage regulator cutout adjustment for possible help. Or buy a new VR. I hope this helps, Keep us informed on the results. JimN
Bob
12-19-2007 20:08:32
 Re: Super A Charging, needs flash every time I use it in reply to Janicholson, 12-19-2007 19:44:36
After it has sat for enough time that you don't expect it will charge, connect a test lead from the generator's "F" terminal to a GOOD ground.
Start it up. If it charges, suspect the VR.
If it does NOT charge, check the voltage at the "A" terminal. If it's less than about 8 Volts, the cutout (in the VR) cannot be expected to pull in.
If this is the case, suspect a short in the armature, or bad field coils, or field poleshoes that have been removed, and are not TIGHTLY fastened inside the generator's "belly", or have dirt, rust, or debris clamped between them and the generator's "belly".
lekander883
12-19-2007 19:39:34
Symptoms sound like your battery? Have you replaced or had it checked?
