F-20 front and rear engine seals
Scott Rukke
12-20-2007 20:06:48
Anyone know a cross reference number to change the felt seals to real neoprene/steel seals for the front and rear crankshaft felt seals? There's gotta be a better way.
Grabatire
12-21-2007 17:41:04
 Re: F-20 front and rear engine seals in reply to Scott Rukke, 12-20-2007 20:06:48
If the rear seal is felt, it may well be the surface of the crank on which the seal runs has a reverse groove in it. This groove is to wipe the felt as the engine rotates and bring whatever oil is oozing past, back into the crankcase. Installing a neoprene seal on this surface will cause the lip of the seal to be climbing in and out of the groove resulting in poor oil control becuse the lip may not seat itself.
I had this experience with a WD9 engine. I installed a felt seal and no more leak.
James Williams
12-21-2007 09:16:05
Scott,Rice equ has them,I looked this morning and I think they are 8.00 apeice
jimmy
Scott Rukke
12-21-2007 11:12:04
 Re: F-20 front and rear engine seals in reply to James Williams, 12-21-2007 09:16:05
They don't have neoprene seals, only felt. I already called them. I was wanting to get rid of the felt.
Andy Motteberg
12-20-2007 20:48:12
Remove your seals and go to NAPA. They should be able to get you new matching seals.
Scott Rukke
12-21-2007 05:05:45
 Re: F-20 front and rear engine seals in reply to Andy Motteberg, 12-20-2007 20:48:12
The seals in there now are shrunken hardened felt. I don't think they can get seals that fit properly off them.
shoeie
12-20-2007 20:21:09
Scott, you might try giving Rice Equipment a call. They carry alot of old Farmall parts. 814-226-9200.
Might be worth a try, I got several Items for my F30 from them, they seem to have about everything. Good Luck.
