Need Help with 240 Utility....
migraine
12-20-2007 20:20:13
Have 240 utility with loader that I plan to work on and get ready to use for business. It has power steering under the dash and is leaking badly. Are there O rings in that unit that go bad or a kit to repair it? This tractor sat for a long time not running and has some issues with a bad miss and low power. Is this maybe valve related as I have changed most of the electrical components and cleaned the carb. Also I put an ad in the classifieds looking for hood and engine skirts for this tractor. I have hood, grill and some other item from a 340 utility that I would be happy to trade or sell. Thanks for any help. Migraine
PaulW_NJ
12-21-2007 04:39:15
 Re: Need Help with 240 Utility.... in reply to migraine, 12-20-2007 20:20:13
third party image
yours look anything like this?
glennster
12-21-2007 05:26:13
 Re: Need Help with 240 Utility.... in reply to PaulW_NJ, 12-21-2007 04:39:15
or this ?
third party image
third party image
PaulW_NJ
12-21-2007 04:28:51
third party image
I bought a 240U last Spring, and my power steering is leaking also. There is a good description of the rebuilding procedure in the I&T Manual. I bought the seals but haven"t taken it apart yet. I had no problem removing the steering linkage U-joints, but you also have to remove the dash to get the power steering out to work on. Here"s a blowup . . . basically there are two seals and an Oring. Got them thru IH
3= #355965
19= #364108
23= #374527
Mine also had a bad miss. A compression check showed zero on one cylinder, and found a few bent pushrods and a frozen exhause valve. Sent the head out. Hope yours is something else.
Good luck. Would appreciate hearing back how the power steering rebuild goes . . . will be my first job in Spring.
