Need dimensions / SH
Gauger
12-21-2007 10:10:48
I need to fabricate a new hydraulic control rod bracket for my SH, part 361101R1. I've misplaced my rusted out part. Can someone provide detailed dimensions so I can make a new one??
pat in wis
12-22-2007 09:53:20
 Re: Need dimensions / SH in reply to Gauger, 12-21-2007 10:10:48
got some measurements and pics
3 holes in side of "U" are 3/16, top 2 have roll pins
"U" is made from 1/8 stock
overall height is 3 3/4
top hole is 5/16 to center from top edge of U
middle hole is 1 1/4 to center from top of U
bottom hole is 2 3/4 to center from top of U
outer width of U is 25/32
inner width of U is 17/32
send email and I can send pics when I figure out how to get them off camera
happy holidays, Pat
pat in wis
12-21-2007 14:13:31
Geoff, I don"t have a parts number book, describe what part you need I can measure and send pic within a couple of days. Stop by sometime if you head up to Adams.
Pat in Wis
Gauger
12-21-2007 18:47:39
 Re: Need dimensions / SH in reply to pat in wis, 12-21-2007 14:13:31
Hi Pat, I feel bad about not stopping by during the fall hunting season. I had the best intentions a few times but you know how that goes. The part I need is the "U" shaped bracket that is held to the light bar with a light clamp and a 1/4" capscrew. The hydraulic lever passes through the "U" and it has a roll pin in it where the rod hooks when in the back position. It has a flat spring that is held by another one of the roll pins that exerts pressure on the rod. I need material thickness, length, width and hole locations, Thanks for your help. Geoff
