magneto points adjustment
joe n/e tx
12-23-2007 07:26:44
If you convert an h4 mag to a distrubitor, What would you set the point gap .020, .013?
El Toro
12-23-2007 07:45:23
 Re: magneto points adjustment in reply to joe n/e tx, 12-23-2007 07:26:44
You would set the disrtibutor points at .020".
Be sure to note where the rotor is pointing before you pull the mag. When installing your distributor just rotate the rotor to the same position as the mag's rotor was pointing. You will need to run battery voltage to your distribuor too. Hal
