Polarity of a Generator
Friend of the f
12-23-2007 11:10:51
Can anyone describe how to polaritice a generator on a B275 IH tractor. Thanks
Friend of the farm
12-23-2007 16:30:22
 Re: Polarity of a Generator in reply to Friend of the farm, 12-23-2007 11:10:51
Thanks Guys I will try that
John T
12-23-2007 12:02:57
Assuming she all wired up correct BEFORE you start it momentarily use a lil wire jumper etc. to flash/jump from the Voltage Regulators BAT terminal over to its ARM/GEN terminal n you oughta get a lil spark.
If the VR's ARM/GEN terminal is hard to get at without accidentally shorting out, jump a wire from the VR BAT terminal direct to the Gennys ARM post.
On tractors with a 2 wire Cutout relay versus a 3 or 4 terminal VR, same thing basically, jump BAT terminal over to ARM/GEN or else the gennys ARM post itself.
If you cant easily get to a VR or Cutout relay,
jump any hot ungrounded battery wire (like say on a starter switch/solenoid input) direct to the Gennsy ARM post n get the spark.
I sometimes say to first dead ground the gennys FLD post but thats usually NOT necessary.
I miss anything??
John T
Janicholson
12-23-2007 11:59:52
With the tractor not running, and the battery charged and hooked up, Use a 10" length of solid copper house wire with the ends stripped 1/2". Use the wire to jump between the regulator Bat or B terminal, and the Gen or Arm terminal. This will spark a little. That is it.
The field wire must be hooked up to the reg, and the reg must be grounded (as it should be. JimN
John T
12-23-2007 12:05:14
 Re: Polarity of a Generator in reply to Janicholson, 12-23-2007 11:59:52
Yo Jim, will an 11 inch piece of wire work lol Just funnin yall in the Christmas Spirit here today
Merry Christmas n God Bless
John T
Janicholson
12-23-2007 13:34:09
 Re: Polarity of a Generator in reply to John T, 12-23-2007 12:05:14
It might, But I never Could find that size when looking. We are going to do a bit of winter driving this evening. Gusting 35mph, snow and 15deg. It is sure white out side. JimN
