H squeaks when shifting
Jfavor
12-23-2007 12:35:12
Shift lever on my H squeaks when shifting. I drained and flushed the tranny about 6 mos. Thought that would cure it. How do I remove the shift lever? Do I just pound the large round pin at the bottom out with a punch? Thanks, Jim
Janicholson
12-23-2007 13:24:19
 Re: H squeaks when shifting in reply to Jfavor, 12-23-2007 12:35:12
Glennster is very correct. If the little pin does not want to move, press downward on the lever a little, they can get worn and the grooves prevent movement. I would use a moly grease, or synthetic grease on the components you find in the hole, and the ball/socket. JimN
glennster
12-23-2007 12:48:18
the big pin you see at the bottom is really 2 metal caps. drive it in a little, the otherside will pop out. then you will see a smaller pin inside there. drive that one back the other way, it will knock the other cap out and then drive the pin out the rest of the way. the shifter will then lift up and out.
Jfavor
12-23-2007 16:24:54
 Re: H squeaks when shifting in reply to glennster, 12-23-2007 12:48:18
Thanks for the info. I thought it looked like a weird pin. So those are caps. Great, I'll give it a go. Jim F
