Cracked Block/Soft Plug??????
justin14054
12-23-2007 17:58:25
Gentlemen,
Brought home an A today.Pulled pan (ice) cleaned out .Put new oil in it and got it running went to add antifreeze and it poured out bottom of bell housing and milky oil again.I assume the blocked is cracked.Is there a soft plug in the rear of the engine above crank????Even if there is It should not run into oil again.Shame very nice tractor.
Justin
Fancy Farm
12-24-2007 05:54:20
 Re: Cracked Block/Soft Plug?????? in reply to justin14054, 12-23-2007 17:58:25
Just replaced sleeve seals in a C that had leaking seals. Pull the pan it is easy to see.
If it is leaking out of the bell housing I doubt it will be sleeve seals entirely but you should check them regardless.
old
12-23-2007 21:16:20
Sounds like its time to split the tractor and have a look see. I know on the B thers one or 2 of them so the same is probably true on the A. Bad thing is you need to remove the clutch to remove the flywheel so you need to aline the clutch disk again
Tom Windsor
12-23-2007 18:48:05
Let us know what You find. Water out of the bell housing would indicate that the soft plug has rusted out.
Bill Geer
12-23-2007 18:43:58
Two soft plugs behind flywheel.
The one on the left is water. the other is for the cam. Milky oil. that tractor has wet sleeves. maybe the o-rings at bottom of sleeve. I would pull the oil pan. Then put antifreeze/water in it. then slde under it with a lite and look for drips Bill
