whats it worth?: 340 Farmall-McCormick
S.M. Kendrick
12-23-2007 19:50:08
I am starting to restore a Farmall-McCormick 340, and I am curious as to what one might offer to buy it for. I am not selling, merely curious as to its value.
Any honest bid would be appreciated. It runs, has no problems, very minor leaks, and I am currently repainting it.
old
12-23-2007 21:19:54
 Re: whats it worth?: 340 Farmall-McCormick in reply to S.M. Kendrick, 12-23-2007 19:50:08
Wide front or trike. Is it a utily type or row crop. Hows the tires on it. What lift does it have if any????? All of that makes for more or less $$$. Could go for as little as $200 not running and bad tires up to around $4000 is wide front and very good tires. So we need a lot more info to say and even then its just a guess
Keith-OR
12-23-2007 23:49:53
 Re: whats it worth?: 340 Farmall-McCormick in reply to old, 12-23-2007 21:19:54
Hey Old, if I am not mistaken 340 Farmall is the row crop and 340 International is the utillity tractor.
Keith
MN Mike
12-24-2007 09:32:26
 Re: whats it worth?: 340 Farmall-McCormick in reply to Keith-OR, 12-23-2007 23:49:53
I paid 3000 for my 340 row crop a few years ago. it has 2 remotes, 3 point conversion (it can handle 2 point as well), trike front, good tires all around, and power steering. came in good runing order with it's work clothes on and a snowblower.
From what I can tell, mine is an international row crop. The TA lever is in a different position depending on whether it is Farmall or International.
S.M. Kendrick
12-23-2007 22:02:37
It is a Tricycle front end, good tires, working hydraulics with no accessories, row crop i believe.
James Williams
12-24-2007 05:19:30
 Re: whats it worth?: 340 Farmall-McCormick in reply to S.M. Kendrick, 12-23-2007 22:02:37
I sold a 340 2 years ago,It was gas good paint,fast hitch and ran perfect,ta worked,good tires for 2500.
jimmy
georgeky
12-23-2007 20:40:53
2 dollars. How could anyone give you an honest or dishonest bid on a tractor that you say is not for sale, and no one can see, test drive or just inspect for all the parts?
