856 3 point
ben poirier
12-25-2007 18:26:56
Can anyone suggest a kit to convert my 856 IH 2-point to a 3-point? I have seen a few, I just cannot tell which one to trust.
Thank you
Ben Poirier
karl f
12-27-2007 16:08:31
 Re: 856 3 point in reply to ben poirier, 12-25-2007 18:26:56
simple way is to get the offset adapter tongs, a top link and a top link attatchment plate. the plate would have to come off a salvage tractor, but everything else is available from many sources, such as yt or your local farm store.
karl f
MN Scott
12-25-2007 19:48:18
If you don't want to use the two point again the best way is visit a salvage yard and buy a complete factory three point hitch off another tractor and bolt it on. A three point set up usally runs about $500 at most yards.
steveormary
12-25-2007 19:30:35
You should be able to get 2pt to 3pt adapters at a CIH dealer or whatever they go by now. Also you will need a bracket for the top link.I had 1 set for cat2 and one set for cat1. Mine were for a 706. Mabe the 856 is cat.3,I dont know.
steveormary
