Leaking carb Help
Dave Ulm
12-26-2007 05:29:39
I have a Carter carburetor on a Farmall B that has developed a leak. The carburetor is a Carter UT and the only number I can find is 625. I need a repair kit does anyone know were I can order a kit, or a kit part number?
georgeky
12-26-2007 06:59:28
 Re: Leaking carb Help in reply to Dave Ulm, 12-26-2007 05:29:39
Might get a kit from YT or maybe Rusty Farmall has them. I would do like Andy says and give it a good cleaning first and try it. More than likely just a spechk of dirt, paint or other debri in there.
Andy Martin
12-26-2007 05:43:47
First take it apart and clean it out. It probably just has a bit of trash under the needle valve and does not need a new one.
If you tear up the gasket, put it back in best you can. They only seal against sloshing fuel and I've used a broken one many times.
