IH 1486 questions
nates90
12-26-2007 08:49:48
Hi,
I have a couple IH 1486 questions. I was wondering about a couple of lights. One of the lights is a oil light when i press the clutch down, and other one is a light that comes on when i push the brakes, i think it is a brake light. I was also wondering what posistion the T/A is best in, the forward or back position. I was also wondering if this tractor had a differential lock on it. Its a 1979 Red Power 1486. Let me know what you guys think.
-Nathan-
Sheepdog in NE
12-26-2007 19:36:19
 Re: IH 1486 questions in reply to nates90, 12-26-2007 08:49:48
The lite that comes on when you step in the clutch is normal. If it comes on when your driving the tractor (clutch pedal back)then you have low PSI. The brake lite coming on means the your brake discs need replacing. The TA lever can be used in any position. If you need more power to pull a load easier pull it back. When you get over the load push it forward. The dif-lock has a button you push with the heel of your foot on the floor boards. No button no dif-lock. Hope this helps. Happy New Year!
