Farmall M Engine codes
puckett
12-26-2007 10:12:14
This message is a reply to an archived post by Greg on a borrowed computer on August 05, 1999 at 18:28:07.
The original subject was "Farmall M Engine codes".
we have a 1951 farmall M. the previous owner thought the engine was a super M. I was hoping to find out if it was or not. We found to engine serial number as follows - BKM 2 26793 Xl or PKM 2 26793 X1
on the prefix was worn and it was unclear for the suffix was a one or an lower case L.
Tractor Tom
12-26-2007 11:57:31
 Re: Farmall M Engine codes in reply to puckett, 12-26-2007 10:12:14
The numbers & letters can be hard to read but it should be a FBKM with the numbers followed by an X1. Fairly common gas M as Mike said, probably a 1950. Super M"s started a little later in the 50"s. Happy Boxing Day!
Mike Farmer
12-26-2007 11:24:23
Hi. According to my register the engine No would actually appear to make it 1950 Farmall M (not super) and the X1 denotes straight gas fuel. I can't find any X on its own with either an upper or a lower case L. MTF
