F-14 engine
Tony S
12-26-2007 21:07:43
I read in an online article that the Farmall A used the same engine as the F-14. Is that true? Is there maybe a power unit that uses the same block as the F-14?
Ron Weber
12-27-2007 17:20:59
 Re: F-14 engine in reply to Tony S, 12-26-2007 21:07:43
They are of the same basic parts, just adapted to a frameless tractor (farmall A) verses a frame tractor (f-12/14). I have used pistons, sleeves, rods, rod bearings, main bearings, valves, and valve guides to rebuilt my f-12/14 fleet with great success. The rest of the parts I am unsure of.
Andrew Z
12-27-2007 07:10:04
As Andy said they are not the same same bore and stroke but thats it. there are some interchangeable parts i belive, i think pistons, sleeves and rods are the same but not 100% on that.
Andrew
Andy Motteberg
12-26-2007 21:36:44
I think they are both C-113 engines, but they are not "the same" engine. The Farmall A engine looks a lot different than a F-14.
