HELP!-Super M: whats this lever do?
edward_m
12-26-2007 22:10:55
I just got hold of a "53 Farmall Super M, and need help in IDing something on the right hand side of the tractor.
Exactly 1/2 way up the side of the gear housing, about 8 inches in front of the brake pedals, is a shaft coming out, with a lever on it that has "M&W Gear Co." molded into the lever. This connects to a control rod that goes up to a holder on the light bar.
Could this be an aftermarket overdrive? I"ve never seen one on any other M or Super M. If I can, I"ll try to post a picture.
Brownie450
12-28-2007 06:12:49
 Re: HELP!-Super M: whats this lever do? in reply to edward_m, 12-26-2007 22:10:55
Glennster---what"s the welder --an aircraft generator? nice set-up.
Dairy Farmer in WI
12-27-2007 18:24:08
it's a M&W 9 speed tranny/ addition. one of my M's had got one but i don't have the leaver or anything for it. i have to shift it from high to low with a vice-grips
DF in WI
glennster
12-27-2007 05:48:28
i agree with the other guys, looks like a 9 speed. i havent seen one with the linkage set up quite like yours, but, theres lots of stuff i havent seen!!! my m has 9 speed also, but it uses a cable to shift it. here is a picture, the 9 speed cable is the third one down from the upper left, it loops around the belt pulley and goes into the trans case. the 9 speed is a real handy add on, it gives you 4 more speed ranges above 4 th gear. i shift mine stopped, in neutral, clutch in, then move the control rod.
third party image
edward_m
12-26-2007 22:21:50
third party image
Heres a link to the images:
Link
http://pixpipeline.com/d/8263cf4bebd8.jpg
steve from mo - dangit!
12-26-2007 22:49:40
 Re: HELP!-Super M: whats this lever do? in reply to edward_m, 12-26-2007 22:21:50
M&W "nine-speed" transmission. Increased the ground speed as well as PTO speed of first four gears. Didn"t change 5th gear because fifth gear was direct drive from input to output.
georgeky
12-26-2007 23:44:43
 Re: HELP!-Super M: whats this lever do? in reply to steve from mo - dangit!, 12-26-2007 22:49:40
Steve, I am no authority on the M&W 9 speed, but I think all the extra gears are between 4th and 5th aren't they?
billde
12-27-2007 07:03:22
 Re: HELP!-Super M: whats this lever do? in reply to georgeky, 12-26-2007 23:44:43
Yes they are between 4th and 5th.
edward_m
12-27-2007 09:06:14
 Re: HELP!-Super M: whats this lever do? in reply to billde, 12-27-2007 07:03:22
Thanks guys....knew I could count on you all to come up with the answers.
