hey george k- 2pt-3pt ??? for ya
glennster
12-27-2007 05:58:01
on this 240 i got, i was thinking bout making a 3 pt for it. i have the hard mount on the bush hog to go from fast hitch to 3 pt, but, if i fabricate a mount for the top link and bolt it to the upper rear deck, there is a pad with three tapped holes under the hydraulic lines, then fabbed up a couple prongs with cat1 and cat 2 holes in it for the fast hitch arms, will that work ok ? i have a 3 pt dirt scoop and a 5 ft woods 3 pt finish mower i could then use on this rascal.
third party image
KIP in MX
12-27-2007 16:50:12
 Re: hey george k- 2pt-3pt ??? for ya in reply to glennster, 12-27-2007 05:58:01
We had a 240U with fast hitch and we bought an aftermarket 3 point kit in the 70īs that contained the lower prongs and a cast iron plate with clevis (that mounted in place of the cover plate directly above the PTO) for the top link. I donīt know if the same setup would work on a Farmall 240.
georgeky
12-27-2007 12:38:14
Glenn, did you get the pics I sent you? Been having email trouble lately. If not let me know and I will try again.
glennster
12-27-2007 13:46:06
 Re: hey george k- 2pt-3pt ??? for ya in reply to georgeky, 12-27-2007 12:38:14
nope they dint show up yet, just checked my email.
georgeky
12-27-2007 16:01:34
 Re: hey george k- 2pt-3pt ??? for ya in reply to glennster, 12-27-2007 13:46:06
Glenn, did you get it this time. I think I was sending it to the wrong Glenn. Had 5 email addresses that started with Glenn, so I sent it to the first one I saw. I sent another hopefully to you this time.
glennster
12-27-2007 18:19:33
 Re: hey george k- 2pt-3pt ??? for ya in reply to georgeky, 12-27-2007 16:01:34
yup george got em that time!!! that set up you have sure is a lot less complicated than the one i was dreaming up in my noggin!!!lol. good thing you sent me those pics, it will save a lot of time fabricating!!!!
georgeky
12-27-2007 19:36:40
 Re: hey george k- 2pt-3pt ??? for ya in reply to glennster, 12-27-2007 18:19:33
Glenn, look at the one in the topic above here. I like it. Under Farmall C 3 point, by Jimmie Joe.
georgeky
12-27-2007 14:38:15
Glenn, send me one to reply to and we will see if that helps. Don't know whats going on here.
georgeky
12-27-2007 09:38:09
Glenn, I think one would also work just slipped around the rockshaft. I have a pic of one I will send you.
old
12-27-2007 08:13:21
Thats about how we did it on a 340. We did make it so there was 3 or 4 holes in it so we could vaire the hook up some which does help with some stuff makeing so you can lower or lift it more
