D310 vs D312
686look2buy
12-27-2007 11:40:24
which motor was better? i knw the 756 had the 310 german and the 686 had the 312 then switched 2 the old 310 on the newer models was there a reason?
M Nut
12-28-2007 06:20:43
 Re: D310 vs D312 in reply to 686look2buy, 12-27-2007 11:40:24
I have a 686 with the 312 in it and like it a lot. It has great power, and is lite on fuel usage. I'd recommend one in a heartbeat.
MN Scott
12-27-2007 18:18:54
I have a 312 in a 686 and a 310 in a 756. Both engines have their strong points and weak points. The 312 starts better, a little more power and is basically a noisey h@llcat always ready to go. The 310 is quieter but harder starting but sips fuel and is a wildcat in kittens clothing just waiting to be opened up. The 310 will last 3 times as long as a 312 between rebuilds but the 310's fuel system parts are high priced. I like my 756 and 686 with the edge to the 686/312 as its a smaller easier handling tractor for the power.
georgeky
12-27-2007 19:21:52
 Re: D310 vs D312 in reply to MN Scott, 12-27-2007 18:18:54
Maybe I need a 310. My 312 has 7000 hours on it and going strong. That would be 21000 before rebuilding the 310 minimum. The 312 does shake the ground. It really roars sometimes.
Steven f/AZ
12-27-2007 13:59:47
Ran a Hydro 86 for a couple of years for a friend, it had the American D312, always started no matter what, ran very nice, and was reasonable on fuel for a Hydro tractor.
Nat 2
12-27-2007 12:27:50
 Re: D310 vs D312 in reply to karl f, 12-27-2007 11:40:24
IH was already in trouble when the 86 series came out and needed to save money wherever they could. They had thousands of left-over D310 and D358 German diesel engines laying around, so they used them in the 686, 786, 886 and 3088 tractors instead of building more American "small-block" diesels.
The American D312 and D360 are the better engines, for sure.
georgeky
12-27-2007 12:36:00
 Re: D310 vs D312 in reply to Nat 2, 12-27-2007 12:27:50
Nat, I figured that money and or company politics played the deciding role.
georgeky
12-27-2007 12:07:52
Don't know the correct answer, but I have a 666 with the 312. A buddy of mine has a 686 with 310. Mine seems to start easier, has a bit more power as well as lugging ability. It even burns less fuel if that makes sense. We have worked them both side by side, and he wants to trade every time we see each other. As to why they switched on the 686 is a mystery to me. Maybe someone can tell us both about the reasoning for the switch to 310.
Jimmy King
12-27-2007 20:36:44
 Re: D310 vs D312 in reply to georgeky, 12-27-2007 12:07:52
The parts manager at the IH dealer I use told me the put the 310 and the 312 in the 686 with no rhyme or rythem. One would come off the line with one and the next with the other.
georgeky
12-27-2007 20:52:32
 Re: D310 vs D312 in reply to Jimmy King, 12-27-2007 20:36:44
I was under the impression that they changed all together at a certain time. I know on my service manual it refers to early 686 with D-312 and late production with D-310. I don't know. I do know that 312 will rock. It never knows the 3X16 plows are on it at 12 inches or more. When dad still done all the buying we got a new 584 in 80. It ws parked beside a 686 with wide front, canopy and I think it was the 310. I said boy that one would be nice, but he thought it was bigger than we needed at the time. Wasn't but about 800 dollars difference in them. I waited a long time to find a good one at good price, but lucked up on the 666 about 5 years ago for 4400 bucks. Had new tires all around, good paint, good TA, and roared to life with a bump of the switch. I like it quite well.
