1066 tellight
Jon Heili
12-27-2007 20:58:54
just wondering what the red light on dash of my 1066 indicates. Thanks
O6'er
12-28-2007 06:29:51
 Re: 1066 tellight in reply to Jon Heili, 12-27-2007 20:58:54
When the light comes on (when you push in the clutch) it means that the hydraulic pressure has been released from the torque amplifier allowing you to shift the tractor. If you ever need to adjust the clutch linkage its very important that you adjust the small linkage on the dump valve that is connected to the cluch linkage. If it is out of adjustment it will be obvious because the tractor won"t shift very well
Jon Heili
12-28-2007 21:43:05
 Re: 1066 tellight in reply to O6'er, 12-28-2007 06:29:51
Thank you
