Utility 300 starter
RLH 55
12-28-2007 22:34:19
Once in a while tractor won"t turn over. Just makes a clicking sound like dead batt. or solinoid. They check ok.you can loosen starter. touch key starter will turn then bolt back up and will be ok.may do this once a week or month. I have had the starter rebuilt, same thing.thanks for any help.
Fromjb2
12-29-2007 05:52:05
 Re: Utility 300 starter in reply to RLH 55, 12-28-2007 22:34:19
We had a 300U new in 1956/57 and it did the same thing from day one. The starter is locking in the ring gear on the flywheel. Just be sure to carry the proper wrench with you, loosen the bolts a few turns, rock the starter and it will pop loose, good to go again.
JimB
RustyFarmall
12-29-2007 05:51:52
That is a common problem on these older tractors. The teeth on the ring gear of the flywheel have become worn and have rough areas. The teeth on the starter drive then become caught in those rough teeth, and everything just sort of locks up. You can continue with what you are doing to make it work, but the only real cure is to split the tractor and replace the ring gear on the flywheel.
NDS
12-29-2007 05:51:43
That is the way they are probaly the most commen problem with 4 cylinder IH tractors. Ring gear on flywheel is probaly worn. There is new type "bendix" that is supposed to cure problem but I have never tried one and do not know how much they help.
Allis chalmers 6
12-28-2007 22:45:58
I own a 300 utility. The starter has little covered holes on it. I put about 10 drops of three in one oil in it twice a year and never have any trouble with starters or solonoids.
