460 sticks in gear
WHISKEY BENT
12-29-2007 09:22:45
GOT A 460 WITH A LOADER ON PROBLEM IS IT ALWAYS STICKS IN GEAR. IF I PUSH SNOW IN ANY GEAR AND HAVE A LOAD ON IT I CANT GET OUT OF GEAR UNLESS I MOVE THE LOADER TO TAKE PRESSURE OFF TRACTOR. HAS NEW CLUTCH AND PRESSURE PLATE. THE TA IS RUSTED SOLID, IS THIS THE PROBLEM? DAD HAS 560 DOES SAME THING ONCE IN A GREAT WHILE HE PULLS TA BACK AND IT REALSES. THE CHUTCH SEAMS TO BE ADJUSTED RIGHT. HELP!
Lee in Iowa
12-29-2007 11:46:39
 Re: 460 sticks in gear in reply to WHISKEY BENT, 12-29-2007 09:22:45
My 560 always had to have the TA back to shift gears until I had the mechanic adjust the clutch and TA now it shifts fine either way. Lee
Steven f/AZ
12-29-2007 09:43:17
The TA needs to release to low range when you push the clutch in - or else it will always stick like that.
