The A that followed me home=Update
justin14054
12-29-2007 19:48:27
Gentlemen,
Brought home an A today.Pulled pan (ice) cleaned out .Put new oil in it and got it running went to add antifreeze and it poured out bottom of bell housing and milky oil again.I assume the blocked is cracked.Is there a soft plug in the rear of the engine above crank????Even if there is It should not run into oil again.Shame very nice tractor.
Justin
justin14054
12-29-2007 19:53:33
 Re: The A that followed me home=Update in reply to justin14054, 12-29-2007 19:48:27
Split it this evening and it was exactly as you guys called it=Soft plug.Changed and back together only about a 2 1/2 hour job.Filled it back up with antifreeze and were good.Ill get here running again in the AM.If there is a leaky sleeve in the engine thats no big deal thats only an hour or two job.It was the leak in the rear I was concerned with (Soft plug).Thanks guys
Justin
