super c hubs
Ken K
12-30-2007 13:20:58
does anyone know what 9 bolt hubs will fit my super c? Thanks in advance
Dale in Ar.
12-30-2007 18:23:44
 Re: super c hubs in reply to Ken K, 12-30-2007 13:20:58
I have a set of 9 hole hubs that were suppose to have come off of an Oliver.The S.C. has 2 1/4 axles and the hubs off of the Oliver were 2 1/4 also But they did not fit.There is about 1/32 difference in the fit.Still trying to figure out what to do to make them fit or trade for a set that will fit or go to plan "b" or "c".
RickB
12-30-2007 14:00:04
Check the axle diameter against an Oliver 66, Super66 or 660. They used 9 bolt hubs even on the cast wheels. 77's may also be the same.
migraine
12-30-2007 17:33:43
 Re: super c hubs in reply to RickB, 12-30-2007 14:00:04
The Oliver hubs are the same diameter but the keys are wider and since they are cast into the hub I have not figured out how to cut them down to fit into the axle slot. I have seen guys use 2010 JD hubs with keys altered to fit and I understand that MMZ or ZA hubs are the same diameter but not very strong. Migraine
