560 Power Steering Problem
Willie Zepeda
12-30-2007 15:47:51
I recently repaired my control valve assembly that attaches to the steering worm cover. I replaced all the o-rings, seals, washers and plug with spring. I also honed it out well and got it to slide soomthly to one side and another. I got it to where it turns very easily to the left but not to the right. Can anyone provide any suggestions? I appreciate your help.
Willie
Jim J
12-31-2007 06:59:38
 Re: 560 Power Steering Problem in reply to Willie Zepeda, 12-30-2007 15:47:51
Did you have steering both ways before you rebuilt the control valve?
ChrisAS
12-30-2007 18:47:44
Willie The steering shaft as to move in and out in order to oparate the hyd valve sounds like maybe only moving one dirrection.
