wd9 hydraulic parts rear weights
JOE-ILLINOIS
12-30-2007 17:02:41
Hi,I am looking at a wd9 with hyd.and rear weights. Is there a market for these if I take them off and what would they be worth, thanks Joe
JOE-ILLINOIS
12-31-2007 04:18:05
 Re: wd9 hydraulic parts rear weights in reply to JOE-ILLINOIS, 12-30-2007 17:02:41
Thanks for the pics Wardner that is what they look like in the pics the owner sent me, also the pump is mounted ahead of the distributor with a tank mounted under fuel tank and a control rod mounted to the right fender with outlets mounted under the seat, thanks Joe
mtdan
12-31-2007 04:46:11
 Re: wd9 hydraulic parts rear weights in reply to JOE-ILLINOIS, 12-31-2007 04:18:05
Joe, I would be interested in the hyd. pump..email me..Dan
Wardner
12-30-2007 23:18:59
I have a few extra pair as well. I am in MA.
The parts book show the first weight as different from any additional weights. They all look the same to me and I think I own eight sets.
Does your hydraulic pump mount to the front of the tractor? SheldonS (two threads up) is looking for one.
Ron in Nebr
12-30-2007 22:20:38
Oh yeah there's a market for 'em. I'd buy the weights from ya if you weren't so far away....wouldn't want to pay shipping cost on those buggers!
JOE-ILLINOIS
12-30-2007 17:43:51
Don't know the numbers but they are bigger than the w4 or w6,the man says they are for a w9, no front weights, there are three on each side, tractor will be for show so don't need all of them if any,tractor is still in Indiana, I am in central Illinois, any ideas on what hyd is worth, thanks Joe
55 50
12-30-2007 17:13:49
Weights are essential for WD-9s if you want to work the tractor to its full capability. Why do you want to sell them?
Wardner
12-30-2007 23:42:42
 Re: wd9 hydraulic parts rear weights in reply to 55 50, 12-30-2007 17:13:49
third party image
Is that enough weight?
migraine
12-30-2007 17:06:56
What is the stamped number on them? Is it 8887-D the same as 600-650 series? Also do you have front weights #9042-D for sale? Migraine
Wardner
12-30-2007 23:23:52
 Re: wd9 hydraulic parts rear weights in reply to migraine, 12-30-2007 17:06:56
Yes, all the 9 series tractors thru 650 use the same rear weights.
glennster
12-30-2007 17:05:54
maaaybeeee..... ..where you at in illinois and how much ya want for em?????
