Farmall C manifold
Greg 2010
12-31-2007 07:12:06
I have a Farmall C that I have taken the manifold off of. The manifold itself is in good shape but the pipe that sticks up that the muffler clamps to is almost rusted away. Will this screw out of the manifold or come apart in some way.Any advice would be appreciated. Also any ideas on where to get an oil pan mine is all bent up. Thanks for you help.
Red Agony
12-31-2007 11:58:17
 Re: Farmall C manifold in reply to Greg 2010, 12-31-2007 07:12:06
I replaced the one on my super C a while back when I was replacing the muffler, it was a real job unscrewing it with two pipe wrenches but we got it off.I think I used a 1 1/2by 8 inch pipe nipple to replace it. Worked out great thanks to some of my freinds here.
RustyFarmall
12-31-2007 07:25:30
Yes, that pipe will screw out, but it probably will not be that easy because it will be rusted in there pretty good. You might want to try sawing it off flush with top of the manifold, and then use a hack saw blade to split what is still inside, and then sort of peel it out. It will take a bit of doing, but you can do it.
GordoSD
12-31-2007 08:07:58
 Re: Farmall C manifold in reply to RustyFarmall, 12-31-2007 07:25:30
5 minute job with a sawsall.As you say, cut it off about 1/4 inch above manifold, saw just down to threads inside, parralell to pipe. Then bend,pry, and peel it out. Chase the threads with a 2 inch NPT tap. New threaded pipe from plumbing supply house.
Gordo
RustyFarmall
12-31-2007 14:24:41
 Re: Farmall C manifold in reply to GordoSD, 12-31-2007 08:07:58
An inexperienced person with a sawzall could do a lot of irrepairable damage in a hurry. Be careful.
