Farmall B - somebody remind me...
Dave H (MI)
12-31-2007 14:20:41
...what causes that static discharge on the ammeter when you turn the switch on. I know it's s'posed to be there but it isn't. Guess I should tell the whole story...
Last ran the B about two months back. Long after I ran it I found the wire between the switch and the ammeter was burnt right in half and I don't know why. Finally replaced that wire today and put it all back together. Hit the switch, pulled the starter, cranks all day long but don't fire. No static discharge on that meter when the switch is on. Couldn't find that in my archives and that is as far as I got when the light failed. So I am first wondering on why that discharge is not there. Hope nothin wrong with my expensive new ebay switch I put on there a few months back! Anyway...I'll look at it again next nice day we have. Happy New Year guys! Some of my best memories of the past year was being helped on this forum.
Dave BN
01-01-2008 06:28:02
 Re: Farmall B - somebody remind me... in reply to Dave H (MI), 12-31-2007 14:20:41
Ahhh, I think you need to find out why that wire burned in half. I'd think that has to do with your tractor not starting. Dave
TomH in PA
12-31-2007 15:50:53
Get a cheapo voltmeter. Disconnect the wire coming out of the coil and see if you're getting anything into it. If you have voltage there it probably the points or condenser.
RustyFarmall
12-31-2007 14:28:28
The ammeter will not show a discharge unless the contact points are closed. If you are cranking the engine and the ammeter hand still does not wiggle, it is probably because the points are dirty and not making contact. Drag a piece of paper or a one dollar bill throught the points and then try again.
