400 Governor
Too Far Gone
12-31-2007 22:34:34
Hi,Im planning on freshening up motor with sleeves and pistons,and the governor isnt as active as Id like anymore.Any helpful hints,or info on rebuild kits?Thanks in advance
ChadS
01-03-2008 08:11:42
 Re: 400 Governor in reply to Keith-OR, 12-31-2007 22:34:34
545IH said: (quoted from post at 16:50:47 01/02/08) Be careful of Chad. He is a Denny's Jr.
Sells crap that doesn't work.
LMAO!!! Get real. ChadS ChadS3@hotmail.com
ChadS
01-01-2008 06:56:07
 Re: 400 Governor in reply to Too Far Gone, 12-31-2007 22:34:34
Take the cover off and have a look. Check to see if there is slop in the weight pins, if so, 2 options,, new, or put in a bigger set of pins by drilling out the old holes in the weights. While the weights are out, you can shave some material off the weights to make them lighter. I dont go past the casting flash on the side of the weight. A stiffer governor spring will change the way it operates for sure. Will open and respond to the hand throttle faster, will hold the carb open longer, during hard working conditions. A good tuned governor can be worth an extra 5-8 HP at rated rpm over stock. After the governor, you will have to go into the carb and increase the jet size, so it will be able to keep up!! Another part to look at is the mechanical advance in the distributor. 90 percent of em I see are broke or stuck. If the rotor feels like it moves and does not snap back fully, this is the sure sign that attention is required. You can go with stock springs, or there are other options for a little added performance. Hope this helps, ChadS ChadS3@hotmail.com www.thetractorshop.com
IH IH M
01-02-2008 12:01:50
 Re: 400 Governor in reply to ChadS, 01-01-2008 06:56:07
"an extra 5-8 HP at rated rpm over stock." WOW! ChadBS and his magic springs. A few extra one in your tool box is good for 10 more HP
ChadS
01-02-2008 14:55:16
 Re: 400 Governor in reply to IH IH M, 01-02-2008 12:01:50
Amazing what a few little springs can do! BOING! little more spring in your step! HAHA! ChadS
545IH
01-02-2008 15:50:47
 Re: 400 Governor in reply to ChadS, 01-02-2008 14:55:16
Be careful of Chad. He is a Denny's Jr. Sells crap that doesn't work.
georgeky
01-01-2008 01:24:10
All engine parts are available for the 400. Including governor parts.
Andy Motteberg
12-31-2007 22:53:20
You should be able to get your parts from the CaseIH dealer.
Too Far Gone
01-01-2008 00:04:35
 Re: 400 Governor in reply to Andy Motteberg, 12-31-2007 22:53:20
Thanks Andy,I figured I could,but sometimes parts arent available anymore.
