Farmall 300 Serial Number
300 Boy
01-01-2008 15:48:56
I am about to overhaul the engine on my Farmall 300 and in looking for an overhaul kit it gives two kits depending upon the serial number. The serial number plate on my tractor is very worn. It appears to be 30450 S. Does this appear to be a valid number? Does anyone know or have the list of serial numbers for the 300? You probably realize this is a row crop tractor since it is a Farmall 300. It"s been a good tractor and is deserving of the rebuild.
Andy Motteberg
01-01-2008 21:05:06
 Re: Farmall 300 Serial Number in reply to 300 Boy, 01-01-2008 15:48:56
My Dad has a 1956 300 and the serial number is 30461. Yours is not much different, so yours is most likely a 56 too. Look in the Serial Numbers section of the left.
D Slater
01-01-2008 17:37:59
I think the reason for the different kits is because they changed connecting rods and pistons to use a smaller wrist pin in later tractors. Most times they list the engine # to go by. Its stamped on a flat pad on right side of engine block between the side cover and head. Engine serial # 48049 and up used the small pins. You should have the small. They started at Farmall gas tractor # 25080. If so you would use the same kit as a C175 engine if using 3-5/8 pistons.
Scott Rukke
01-01-2008 16:31:34
That number appears to be too high for a 300. At least according to the serial numbers listed here.
Year Starting Serial Number
1954 501
1955 1779
1956 23224
Hugh MacKay
01-01-2008 16:55:36
 Re: Farmall 300 Serial Number in reply to Scott Rukke, 01-01-2008 16:31:34
Scott: Those are beginning serial numbers for each year. Look at John's post, he is correct.
Scott Rukke
01-01-2008 18:18:13
 Re: Farmall 300 Serial Number in reply to Hugh MacKay, 01-01-2008 16:55:36
Yeah I knew that. Brain fade.
John - OH
01-01-2008 16:07:08
Looks like 30450 would be a 1956 according to my book, and close to the end at that. 30508 is the last serial number shown for 1956. Hope that helps.
